Aller au contenu principal
Surface Laptop Studio SSD Replacement
Ce dont vous avez besoin
  1. Surface Laptop Studio SSD Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio SSD Replacement: étape 2, image 1 de 2 Surface Laptop Studio SSD Replacement: étape 2, image 2 de 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio SSD Replacement: étape 3, image 1 de 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio SSD Replacement: étape 4, image 1 de 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio SSD Replacement: étape 5, image 1 de 2 Surface Laptop Studio SSD Replacement: étape 5, image 2 de 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 1 de 2 Surface Laptop Studio SSD Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 2 de 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio SSD Replacement, SSD: étape 7, image 1 de 1
    • After removing the devices battery, locate the SSD next to the mother board.
  8. Surface Laptop Studio SSD Replacement: étape 8, image 1 de 1
    • Remove the single 3 mm screw that secures the SSD.
  9. Surface Laptop Studio SSD Replacement: étape 9, image 1 de 1
    • Slide the SSD directly out of its socket.
2 autres ont terminé cette réparation.
Nate Ball
Membre depuis le 02/14/23
669 Réputation
5 tutoriels rédigés
Équipe
3 commentaires
Is this strip tape or it metal? Is there replacements for it? I habe been trying to find it but I can only find tape as an alternative to this part.
Luis Ruiz - Réponse
I tried the SSD upgrade with two different WD products (1TB black and 1TB blue) and with both I had problems: Random blue screens and after some time, computed could not find the SSD anymore. Looks like it has something to do with drive consuming too much power but I am not sure. I am now back on original 256 GB SSD, since I can't find what is causing compatibility issues.
Pohistvo123 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 89
30 derniers jours : 396
Total : 5,801
