Aller au contenu principal
Surface Laptop Studio Surflink Port Replacement
Ce dont vous avez besoin
  1. Surface Laptop Studio Surflink Port Replacement, Lower Case: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Remove the rubber cosmetic strip along the outside edge of the back plate with tweezers.
  2. Surface Laptop Studio Surflink Port Replacement: étape 2, image 1 de 2 Surface Laptop Studio Surflink Port Replacement: étape 2, image 2 de 2
    • Remove the two rubber feet on the lower case with an opening tool.
  3. Surface Laptop Studio Surflink Port Replacement: étape 3, image 1 de 1
    • Remove the two screws with a T3 Torx screwdriver.
  4. Surface Laptop Studio Surflink Port Replacement: étape 4, image 1 de 1
    • Remove the seven screws securing the lower case with a T3 Torx screwdriver.
  5. Surface Laptop Studio Surflink Port Replacement: étape 5, image 1 de 2 Surface Laptop Studio Surflink Port Replacement: étape 5, image 2 de 2
    • Lift the lower case gently and set it above the device.
    • Take care not to strain the battery cable as you move the lower case.
  6. Surface Laptop Studio Surflink Port Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 1 de 2 Surface Laptop Studio Surflink Port Replacement, Surface Laptop Studio Battery Disconnection: étape 6, image 2 de 2
    • Disconnect the battery cable by lifting the pull tab until it "clicks."
  7. Surface Laptop Studio Surflink Port Replacement, Surflink Port: étape 7, image 1 de 3 Surface Laptop Studio Surflink Port Replacement, Surflink Port: étape 7, image 2 de 3 Surface Laptop Studio Surflink Port Replacement, Surflink Port: étape 7, image 3 de 3
    • Remove the left I/O bracket by unscrewing the the three M1109237 screws with your T3 Torx Screwdriver.
  8. Surface Laptop Studio Surflink Port Replacement: étape 8, image 1 de 2 Surface Laptop Studio Surflink Port Replacement: étape 8, image 2 de 2
    • Remove the two M1149393 screws that secure the ribbon cable with your T3 Torx screwdriver.
  9. Surface Laptop Studio Surflink Port Replacement: étape 9, image 1 de 1
    • Lightly disconnect the flat-top connector by lifting it straight up with an opening tool.
  10. Surface Laptop Studio Surflink Port Replacement: étape 10, image 1 de 1
    • Remove the two M1149393 screws that secure the Surflink port with your T3 Torx screwdriver.
  11. Surface Laptop Studio Surflink Port Replacement: étape 11, image 1 de 1
    J'achète
    • Lift the surflink port out and up with your tweezers.
Nate Ball
Membre depuis le 02/14/23
669 Réputation
5 tutoriels rédigés
Équipe
Un commentaire
Dont even bother reading this unless you already have aquired the surflink port. They are basically impossible to get the parts through ifixit and microsoft. in europe at least.
Robin Trapman - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 57
Total : 673
