Aller au contenu principal
Introduction
Follow this guide to replace your power supply unit
  1. Lay the Surface face down on a padded surface Be careful not to scratch the screen when laying it face down Remove the four rubber feet at each corner concealing the Torx screws
    • Lay the Surface face down on a padded surface
    • Be careful not to scratch the screen when laying it face down
    • Remove the four rubber feet at each corner concealing the Torx screws
    • Remove the four Torx screws under the rubber feet.
    • Two screws on the upper corners are longer than two screws on the lower corners.
    • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
  2. Remove five torx screws holding the two fans to the midframe Remove the two fans
    • Remove five torx screws holding the two fans to the midframe
    • Remove the two fans
    • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
    • Four large torx screws and four small torx screws hold the midframe to the upper frame.
    • Remove four large torx screws holding the midframe
    • Remove four small torx screws holding the midframe
  3. Slowly remove the midframe
    • Slowly remove the midframe
    • Be careful: the speaker on the midframe is still attached to the motherboard
    • Detach the connectors for the two fans and the speaker
  4. A screw retaining the power supply is under the hard drive so both the hard drive and the heat sink assembly must be removed Remove four spring loaded torx screw labeled 1 to 4 Remove four torx screw labeled 5 to 7
    • A screw retaining the power supply is under the hard drive so both the hard drive and the heat sink assembly must be removed
    • Remove four spring loaded torx screw labeled 1 to 4
    • Remove four torx screw labeled 5 to 7
    • Remove 5mm hex mounting post
    • Use a spudger to remove the heatsink assembly from the motherboard
  5. Remove three torx screws holding the hard drive brackets Remove 5mm hex mounting post
    • Remove three torx screws holding the hard drive brackets
    • Remove the hard drive and disconnect the SATA/SATA power cable
  6. Remove a Phillips screw still retaining the power supply Remove a torx screw retaining the power supply cable
    • Remove a Phillips screw still retaining the power supply
    • Remove a torx screw retaining the power supply cable
    • Unplug the power supply from the motherboard
    • Lift the power supply up and away from the base unit
4 autres ont terminé cette réparation.
The Raptor
Membre depuis le 27/11/2016
5 851 Réputation
6 tutoriels rédigés
3 commentaires
Does anyone have a source for a new power supply?
AustinMike - Réponse
Still no source fora power supply huh?
Steve - Réponse
I recently purchased a MS Surface Studio 6th Generation computer and it seems that the USB ports don’t work properly and the headphone jack is dead…. Any ideas what I need to do to fix it before I send it back?
reowens - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 63
Total : 2,324
