Aller au contenu principal
SwagTron T1 Back Panels Replacement
Ce dont vous avez besoin
  1. SwagTron T1 Back Panels Replacement, Back Panels: étape 1, image 1 de 1
    • Ensure that the SwagTron is off.
    • Turn the SwagTron upside down to see the underside.
  2. SwagTron T1 Back Panels Replacement: étape 2, image 1 de 3 SwagTron T1 Back Panels Replacement: étape 2, image 2 de 3 SwagTron T1 Back Panels Replacement: étape 2, image 3 de 3
    • Unscrew the eighteen 10mm screws that secure the back panels using a Phillips #2 screwdriver.
    • The screws are tightly in place. It will take effort to screw them out.
    • The panel is still attached to the SwagTron by wires that go to the motherboard.
    • Carefully lift the panels off
  3. SwagTron T1 Back Panels Replacement: étape 3, image 1 de 3 SwagTron T1 Back Panels Replacement: étape 3, image 2 de 3 SwagTron T1 Back Panels Replacement: étape 3, image 3 de 3
    • Follow the wires from the panels to the motherboard.
    • You may need to cut any zip ties that are holding the wires together.
    • There is one connection on the battery side and three on the other side that must be removed.
    • These connections may be difficult to remove. Try to securely press the connection and pull firmly.
    • Your back panels are now completely removed.
Adrian Abarca
Membre depuis le 04/18/17
360 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S17-G5, Banghart Spring 2017 Membre de l'équipe Cal Poly, Team S17-G5, Banghart Spring 2017
CPSU-BANGHART-S17S17G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 667
