Aller au contenu principal
Swagtron T3 Wheel Replacement
Ce dont vous avez besoin
  1. Swagtron T3 Wheel Replacement, Cover: étape 1, image 1 de 2 Swagtron T3 Wheel Replacement, Cover: étape 1, image 2 de 2
    • Make sure the hoverboard is completely powered off and unplugged from any outlets.
    • Flip the Swagtron so that the footpads are facing the ground.
    • Unscrew the sixteen 9.4 mm Phillips #1 machine screws on the side of the Swagtron that is now facing upwards.
  2. Swagtron T3 Wheel Replacement: étape 2, image 1 de 3 Swagtron T3 Wheel Replacement: étape 2, image 2 de 3 Swagtron T3 Wheel Replacement: étape 2, image 3 de 3
    • Be careful with the small blue capacitors indicated by the orange box. There are many of these capacitors in the device.
    • Slowly lift the backside cover.
    • Both sides lift up the same way, but the motherboard is under one side and the battery is under the other.
    • Detach the four cables connected to the cover by pinching the connector clips and pulling the cables out:
    • Three cables on the motherboard side.
    • Two red cables with white connectors and one white cable with a white connector.
    • One yellow cable with a black connector on the battery side.
    • After detachment, you should be able to completely remove the backside cover.
  3. Swagtron T3 Wheel Replacement, Wheel: étape 3, image 1 de 1
    • Unscrew the six 11.2 mm Phillips machine screws from the inside of the wheel.
    • You many need to spray a thin lubricant, such as PB Blaster, directly onto each of the six screw points to loosen them.
  4. Swagtron T3 Wheel Replacement: étape 4, image 1 de 2 Swagtron T3 Wheel Replacement: étape 4, image 2 de 2
    • Pull the wheel off of its base.
    • The wheel has a strong magnetic connection to the base, so separating the them will require a lot of force.
Klara Perkins
Membre depuis le 04/10/17
412 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S13-G3, Forte Spring 2017 Membre de l'équipe Cal Poly, Team S13-G3, Forte Spring 2017
CPSU-FORTE-S17S13G3
4 membres
4 tutoriels rédigés
3 commentaires
Hi,
my girl Swagtron T6 wheel is flat. Probably it is a nail hole. We are faraway from US, so I have to do it by myself. Can I get the wheel out for tire repairing?
Can you help me please?
Thanks
Susana Arzuaga - Réponse
Can't the wheel off
Christopher Primo - Réponse
I have a T6 Swagtron and I am struggling to get the wheel off. Are these magnets really that strong? It feels like there is something else holding the wheel in place. I tried prying it but doesn’t seem like its doing enough.
photostudiomilk - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 18
Total : 4,053
