Aller au contenu principal
Sylvania SDVD9004 Motherboard Replacement
Ce dont vous avez besoin
  1. Sylvania SDVD9004 Motherboard Replacement, Back cover: étape 1, image 1 de 1
    • Remove ten 7mm Phillips #0 screws.
    • Remove four 5mm Phillips #0 screws.
  2. Sylvania SDVD9004 Motherboard Replacement: étape 2, image 1 de 2 Sylvania SDVD9004 Motherboard Replacement: étape 2, image 2 de 2
    • Flip the device over.
    • Lift the top.
  3. Sylvania SDVD9004 Motherboard Replacement: étape 3, image 1 de 1
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
  4. Sylvania SDVD9004 Motherboard Replacement, CD Drive: étape 4, image 1 de 3 Sylvania SDVD9004 Motherboard Replacement, CD Drive: étape 4, image 2 de 3 Sylvania SDVD9004 Motherboard Replacement, CD Drive: étape 4, image 3 de 3
    • Wedge head lightly between drive and bottom of tab.
    • Repeat on both sides.
    • Gently pull out ribbon
  5. Sylvania SDVD9004 Motherboard Replacement: étape 5, image 1 de 1
    • Drive Removal
    • Use Philip's screw driver to remove three 7 mm screws.
    • Rotate counter clockwise to loosen screws.
  6. Sylvania SDVD9004 Motherboard Replacement: étape 6, image 1 de 1
    • Follow the red and black cables to the motherboard point of attachment.
    • Use a Flat head screwdriver.
    • Place head of driver into the grove of plug and port.
    • Wedge on all sides evenly to work out plug slowly.
    • Remove small and large plugs.
  7. Sylvania SDVD9004 Motherboard Replacement, Motherboard: étape 7, image 1 de 3 Sylvania SDVD9004 Motherboard Replacement, Motherboard: étape 7, image 2 de 3 Sylvania SDVD9004 Motherboard Replacement, Motherboard: étape 7, image 3 de 3
    • Remove Ribbon from Rear Panel
  8. Sylvania SDVD9004 Motherboard Replacement: étape 8, image 1 de 1
    • Anchor screw removal
    • Use Philip's head screwdriver
    • Place head of driver into screw on mother board.
    • Remove all four screws
  9. Sylvania SDVD9004 Motherboard Replacement: étape 9, image 1 de 1
    • Lift motherboard to expose battery
Sarah Henry
Membre depuis le 10/31/16
417 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team 5-10, Williams Fall 2016 Membre de l'équipe Baylor, Team 5-10, Williams Fall 2016
BU-WILLIAMS-F16S5G10
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 9
Total : 389
