Introduction
Passez à l'étape 1 ↓Replace the the gyro on your Syma S107 so that it stops self destructing.
Ce dont vous avez besoin
Pièces
Outils
Outil utilisé dans cette étape :Tweezers$4.99
Using tweezers, gently remove the two stabilizing links by pulling straight away from the point of connection.
Remove the gyro carriage by removing the following screws:
Two 5.6mm Phillips #0.
Again using tweezers gently remove the stabilizing links from the blade carriage by pulling straight away from the point of connection.
7 autres ont terminé cette réparation.
6 commentaires de tutoriel
Thank you for this guide! This has fixed the issue and made a 35 year old boy very happy!
Cheers thanks too this page I fixed problem great , Martin
I’m halfway there and grateful for the directions. But I’m not having any luck removing the broken plastic pins from the blade carriage. I’ve tried using a needle but no luck. Did anyone else come up against this?
