Introduction
Here's a step-by-step tutorial to dismount each piece of the NAS until you reach the motherboard.
'Note: the interest of this tutorial is however limited.'
Internal drives and fan apart, none of the internal component can be upgraded or added.
The dismantling time is estimated at 45 minutes (a single experiment on the timer). That said, it is certainly achievable in 10/15 minutes.
The photographs were taken with a CANON EOS 7D and using a portable LED studio.
Outils
Pièces
Aucune pièce spécifiée.
Here are the different interesting faces of the case: front (led indicator, power button), rear (connectors, fans, power).
Remove the 2 screws on the back of the case at the top and bottom
Slide the cover forward, then slide it out (here, to the left).
Insérez ici votre traduction
Remove the 4 screws located on the side of each drive.
then just pull the drives out from the bay
To reassemble your device, follow the instructions in reverse order.
Merci à ces traducteurs :
83%
Sébastien nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
