Aller au contenu principal
TCL Stylus Battery Replacement
Ce dont vous avez besoin
    • Press and hold the Power button for 2 seconds.
    • Then, select "Power off".
  1. TCL Stylus Battery Replacement, Remove back panel: étape 2, image 1 de 3 TCL Stylus Battery Replacement, Remove back panel: étape 2, image 2 de 3 TCL Stylus Battery Replacement, Remove back panel: étape 2, image 3 de 3
    • Insert a jimmy tool into the casing to create a gap.
    • Then, put a plastic pick in the gap and remove the jimmy tool.
    • Finally, lift up to remove the panel.
  2. TCL Stylus Battery Replacement, Remove plastic shielding: étape 3, image 1 de 2 TCL Stylus Battery Replacement, Remove plastic shielding: étape 3, image 2 de 2
    • Remove the 10 Phillips screws holding the plastic shielding from the motherboard.
    • Then, grab a pick and put in in the slot show on picture 2.
    • You should then be able to lift the rest of it off.
  3. TCL Stylus Battery Replacement, Unplug battery: étape 4, image 1 de 2 TCL Stylus Battery Replacement, Unplug battery: étape 4, image 2 de 2
    • With your fingernail, lift up the battery connector.
  4. TCL Stylus Battery Replacement, Unpeel tape: étape 5, image 1 de 2 TCL Stylus Battery Replacement, Unpeel tape: étape 5, image 2 de 2
    • Unpeel the tape holding the battery.
  5. TCL Stylus Battery Replacement, Remove battery: étape 6, image 1 de 2 TCL Stylus Battery Replacement, Remove battery: étape 6, image 2 de 2
    • Pull on the sticker located on the middle of the left side (colored green) of the battery to remove it.
    • NOTE: The pull tab may have resistance.
Lee Hunt
Membre depuis le 12/08/16
1 025 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 88
Total : 941
