Aller au contenu principal
TDK Life on Record A33 AC Adapter Prongs Replacement
Ce dont vous avez besoin
  1. TDK Life on Record A33 AC Adapter Prongs Replacement, Prongs: étape 1, image 1 de 1
    • Locate the small hole, which is in the shape of a semicircle. It is below the plastic piece that has the prongs attached.
  2. TDK Life on Record A33 AC Adapter Prongs Replacement: étape 2, image 1 de 2 TDK Life on Record A33 AC Adapter Prongs Replacement: étape 2, image 2 de 2
    • Push the button that is inside the hole with the metal spudger and hold it down.
    • While the button is being pressed, push up on the prongs with your thumb. If the prongs aren't moving, you might need to push down a little harder on the button.
    • The button does not need to be pressed when sliding the prongs back in.
  3. TDK Life on Record A33 AC Adapter Prongs Replacement: étape 3, image 1 de 1
    • Remove the prongs from the AC Adapter. Any repairs on the prongs can now be easily done.
Matthew Festa
Membre depuis le 10/16/15
808 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 2,540
