Aller au contenu principal
TDK Life on Record A33 Speaker Replacement
Ce dont vous avez besoin
  1. TDK Life on Record A33 Speaker Replacement, Speaker Guard: étape 1, image 1 de 1
    • Push the nylon or metal spudger in the corner of the speaker guard.
  2. TDK Life on Record A33 Speaker Replacement: étape 2, image 1 de 1
    • Slowly lift the speaker up enough so that you can slide around the speaker guard.
  3. TDK Life on Record A33 Speaker Replacement: étape 3, image 1 de 2 TDK Life on Record A33 Speaker Replacement: étape 3, image 2 de 2
    • Slide the nylon or metal spudger all around the speaker guard.
  4. TDK Life on Record A33 Speaker Replacement: étape 4, image 1 de 1
    • Remove the speaker guard. You can now replace the speaker guard on your TDK Life on Record A33.
  5. TDK Life on Record A33 Speaker Replacement, Speaker: étape 5, image 1 de 2 TDK Life on Record A33 Speaker Replacement, Speaker: étape 5, image 2 de 2
    • Remove all (4) 3mm screws in the middle speaker using a Phillip's head screwdriver.
    • You can also remove the speakers on the left and right.
  6. TDK Life on Record A33 Speaker Replacement: étape 6, image 1 de 2 TDK Life on Record A33 Speaker Replacement: étape 6, image 2 de 2
    • Do not rip the wires inside the speaker when trying to open the middle speaker on the device.
    • Create an opening in the speaker by holding the device up and carefully grabbing the side of the speaker that pops out.
  7. TDK Life on Record A33 Speaker Replacement: étape 7, image 1 de 2 TDK Life on Record A33 Speaker Replacement: étape 7, image 2 de 2
    • Wear safety goggles and have something to absorb the smoke from the soldering iron just in case.
    • Do not burn the wires of the speaker.
    • Remove the solder that connects the wires to the speaker. You should be able to now remove the speaker and replace it.
2 autres ont terminé cette réparation.
Matthew Phou
Membre depuis le 10/20/15
448 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-2, Catania Fall 2015
UMASSD-CATANIA-F15S4G2
4 membres
5 tutoriels rédigés
3 commentaires
Where can I buy the woofer?
stevealvarado54 - Réponse
Really, stevealvarado! What's The point of taking this all apart if you don't have a replacement to put in?
Van Moon - Réponse
If l need a second opinion about which speaker is blown, who or where can can l get it diagnosed?
Tony - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 24
Total : 4,419
