Aller au contenu principal
TDK Life on Record Trek 360 Battery Replacement
Ce dont vous avez besoin
  1. TDK Life on Record Trek 360 Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn the TDK Life on Record Trek 360 on its side as shown and remove the four 8 mm screws holding the battery cover in place with the T-5 torx screw bit.
    • Before beginning this guide, be sure that the battery is completely drained of charge. This prevents electrical injury.
  2. TDK Life on Record Trek 360 Battery Replacement: étape 2, image 1 de 3 TDK Life on Record Trek 360 Battery Replacement: étape 2, image 2 de 3 TDK Life on Record Trek 360 Battery Replacement: étape 2, image 3 de 3
    • Place a metal spudger between the small crease of the battery cover and the device, and apply downward pressure.
    • Pull down like a lever while continuing to apply downward pressure.
  3. TDK Life on Record Trek 360 Battery Replacement: étape 3, image 1 de 2 TDK Life on Record Trek 360 Battery Replacement: étape 3, image 2 de 2
    • Using a spudger or plastic opening tool, lift the battery from the bottom right and rotate it upwards and toward you.
    • These images show the use of a metal spudger. Use a plastic opening tool or standard spudger to prevent damage to your device.
    • The battery does not lift STRAIGHT UP. Lifting in this manner could damage the battery, wires, and/or the device.
  4. TDK Life on Record Trek 360 Battery Replacement: étape 4, image 1 de 3 TDK Life on Record Trek 360 Battery Replacement: étape 4, image 2 de 3 TDK Life on Record Trek 360 Battery Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • To remove the battery, use one hand to pull on the battery wires, use tweezers to pull on the connecting head of the speaker.
    • Take extreme caution when pulling. This requires some force, but pulling with extreme force can cause damage to the wire/battery/or device.
3 autres ont terminé cette réparation.
Helen Huynh
Membre depuis le 09/14/15
338 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 1-2, Bruce Fall 2015 Membre de l'équipe CSU Fullerton, Team 1-2, Bruce Fall 2015
CSUF-BRUCE-F15S1G2
3 membres
5 tutoriels rédigés
2 commentaires
Good guide, but what battery fits?
Niklas Aronsson - Réponse
I have opened the hatch but I can’t lift the battery out. My battery seems to be glued in place…. :(
EDIT: I broke several cheap plastic spudgers, but when I finally used a metallic one, the battery pack came right out. Yes, I read that one shouldn’t use a metallic one, but this battery is dead like the dodo anyway.
Barbafant Fant - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 27
Total : 3,702
