Aller au contenu principal
TDK Life on Record Trek 360 Handle Replacement
Ce dont vous avez besoin
  1. TDK Life on Record Trek 360 Handle Replacement, Disassembling TDK Life on Record bottom panel: étape 1, image 1 de 1
    • Remove the four rubber feet of the device using a metal spudger.
  2. TDK Life on Record Trek 360 Handle Replacement: étape 2, image 1 de 2 TDK Life on Record Trek 360 Handle Replacement: étape 2, image 2 de 2
    • Remove the four 9 mm Phillips #0 screws located under the feet of the device.
    • Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
  3. TDK Life on Record Trek 360 Handle Replacement: étape 3, image 1 de 2 TDK Life on Record Trek 360 Handle Replacement: étape 3, image 2 de 2
    • Pull the bottom cover of the device towards you.
  4. TDK Life on Record Trek 360 Handle Replacement: étape 4, image 1 de 2 TDK Life on Record Trek 360 Handle Replacement: étape 4, image 2 de 2
    • Remove the four 13 mm Phillips #1 screws.
  5. TDK Life on Record Trek 360 Handle Replacement: étape 5, image 1 de 2 TDK Life on Record Trek 360 Handle Replacement: étape 5, image 2 de 2
    • Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
    • The woofer is the circular component located at the bottom of the device after the bottom cover has been removed
    • Pull apart the compartments by applying force in opposite directions.
    • Do not pull with extreme force!! There are many electrical wires inside the device that can become damaged if the bottom panel is removed without care
  6. TDK Life on Record Trek 360 Handle Replacement: étape 6, image 1 de 1
    • Disconnect the seven cables attached to the motherboard.
    • Do not use too much force when pulling on the wires. Pulling with too much force can damage the wires.
  7. TDK Life on Record Trek 360 Handle Replacement, Air Vent Tube: étape 7, image 1 de 1
    • Remove the four 8 mm Phillips #1 screws.
  8. TDK Life on Record Trek 360 Handle Replacement: étape 8, image 1 de 3 TDK Life on Record Trek 360 Handle Replacement: étape 8, image 2 de 3 TDK Life on Record Trek 360 Handle Replacement: étape 8, image 3 de 3
    • place your hands on each side of the air vent and then place your index finger on the thin plastic half circle that holds the vent in place.
    • Pull the plastic half circle towards you.
    • Put both of your hands inside the tube as shown and push away from you.
  9. TDK Life on Record Trek 360 Handle Replacement, Motherboard: étape 9, image 1 de 2 TDK Life on Record Trek 360 Handle Replacement, Motherboard: étape 9, image 2 de 2
    • Remove the four wired clips by pulling on the wires.
    • Remove the three 6 mm Phillips #1 screws.
  10. TDK Life on Record Trek 360 Handle Replacement: étape 10, image 1 de 1
    • Remove the volume control knob, which is located at the front of the speaker, by pulling it towards you.
  11. TDK Life on Record Trek 360 Handle Replacement: étape 11, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, turn the nut counter-clockwise and remove the nut.
  12. TDK Life on Record Trek 360 Handle Replacement: étape 12, image 1 de 1
    • Push the metal part that holds the volume control knob away from you.
  13. TDK Life on Record Trek 360 Handle Replacement, Handle: étape 13, image 1 de 1
  14. TDK Life on Record Trek 360 Handle Replacement: étape 14, image 1 de 2 TDK Life on Record Trek 360 Handle Replacement: étape 14, image 2 de 2
    • Use your left hand to hold the top portion of the speaker in place.
    • Using your right hand, pull the handle away from the device.
Eduardo Barrios
Membre depuis le 09/14/15
323 Réputation
2 tutoriels rédigés
Équipe
CSU Fullerton, Team 1-2, Bruce Fall 2015 Membre de l'équipe CSU Fullerton, Team 1-2, Bruce Fall 2015
CSUF-BRUCE-F15S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 457
