Aller au contenu principal
TDK Life on Record Trek Max A34 Small Speaker Replacement
Ce dont vous avez besoin
  1. TDK Life on Record Trek Max A34 Small Speaker Replacement, Small Speaker: étape 1, image 1 de 2 TDK Life on Record Trek Max A34 Small Speaker Replacement, Small Speaker: étape 1, image 2 de 2
    • Use a TR7 screwdriver to remove the screws from the battery cover located on the underside of the device.
    • Remove the battery cover.
  2. TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 2, image 1 de 2 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 2, image 2 de 2
    • Unplug and remove the battery.
    • Use a metal spudger to pry off the rubber padding.
  3. TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 3, image 1 de 3 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 3, image 2 de 3 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 3, image 3 de 3
    • Use a J00 screwdriver to unscrew the screws that are under the rubber pads.
    • Remove the battery holder and be sure to thread the wires through the hole within the part.
  4. TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 4, image 1 de 3 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 4, image 2 de 3 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 4, image 3 de 3
    • Use a metal spudger to pry off the front and back mesh screens.
    • You may need to move the metal spudger along the edge of the screen to remove it easier.
  5. TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 5, image 1 de 3 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 5, image 2 de 3 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 5, image 3 de 3
    • Use the a metal spudger to pry up the rubber cover on the top surface of the device.
    • Peel off the rubber cover to reveal the buttons and screws underneath.
  6. TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 6, image 1 de 2 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 6, image 2 de 2
    • Use a J00 screwdriver to unscrew the screws that hold the top cover in place.
    • Remove the top cover.
  7. TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 7, image 1 de 2 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 7, image 2 de 2
    • On the backside of the device, unscrew the case screws with a J00 screwdriver.
    • Only the screws on the backside are needed to hold the frame together, do not remove screws on the front.
    • Once the screws are removed, separate the two frame pieces.
  8. TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 8, image 1 de 3 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 8, image 2 de 3 TDK Life on Record Trek Max A34 Small Speaker Replacement: étape 8, image 3 de 3
    • The following steps can be applied to either the left or the right speaker.
    • Use a J00 screwdriver to unscrew the four screws that secure the speaker.
    • The speaker should fall out naturally. If the speaker is stuck, use a plastic opening tool or a metal spudger to gently lift it out.
    • Desolder the black and red speaker wires.
    • Review the Desolder guide if you are unfamiliar with soldering.
Mario Lazaga
Membre depuis le 01/14/19
1 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G3, Wilson Spring 2019 Membre de l'équipe IUPUI, Team S3-G3, Wilson Spring 2019
IUPUI-WILSON-S19S3G3
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 17
Total : 359
