Aller au contenu principal
TI-84 Plus Silver Edition Battery Spring Replacement
Ce dont vous avez besoin
  1. TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: étape 1, image 1 de 2 TI-84 Plus Silver Edition Battery Spring Replacement, Battery Spring: étape 1, image 2 de 2
    • Unscrew all six 8.5mm screws in the back of the calculator using the T6 star screw bit.
  2. TI-84 Plus Silver Edition Battery Spring Replacement: étape 2, image 1 de 2 TI-84 Plus Silver Edition Battery Spring Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool to pry the calculator open.
    • Use your hands to firmly grasp and pull apart the calculator when a reasonable gap has been made.
  3. TI-84 Plus Silver Edition Battery Spring Replacement: étape 3, image 1 de 1
    • Remove the battery in order to access the battery spring that needs to be replaced.
  4. TI-84 Plus Silver Edition Battery Spring Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Remove the damaged spring using the tweezers.
  5. TI-84 Plus Silver Edition Battery Spring Replacement: étape 5, image 1 de 2 TI-84 Plus Silver Edition Battery Spring Replacement: étape 5, image 2 de 2
    • Pick up the new spring with the tweezers.
    • Insert the new spring with the tweezers.
    • Gently push the new spring into place using your finger.
  6. TI-84 Plus Silver Edition Battery Spring Replacement: étape 6, image 1 de 1
    • Test by replacing the battery that was taken out to check the connection.
Clayton Rudolph
Membre depuis le 09/15/20
157 Réputation
1 tutoriel rédigé
Équipe
2 commentaires
Hi! So where can I get the spring part?
Aleyson B.Hunter - Réponse
Hey! You can make a fix by bending a bit of stripped copper wire. I uploaded some Images of my fix, it worked reliably you just had to be careful when replacing batteries.
However i have found my original spring. But whiles searing for one to buy i stumble on many on Aliexpress that you could bend to the correct shape, Maybe this FW-DCTHZ9X20 (Seller) would work as the end part of the original spring is as well 9 mm.
Julian Lundh -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 662
