Introduction
If some of the buttons of the TI-84 Silver Plus Edition do not work but the buttons appear to be intact, you may need to replace the keyboard mat.
Ce dont vous avez besoin
Insert your index finger in the open slot below the keys.
Apply a firm upward force until the bottom two tabs located near the bottom of the plate come off.
Push firmly down on the tab located on the back of the calculator near the center.
Pull the tab up, lifting it off of the calculator and exposing the batteries.
Using the Phillips #00 Screwdriver, unscrew the 15 mm screw holding the backup battery cover, located above the main battery area.
Unscrew the six 8.5 mm screws located on the perimeter of the back cover using the Precision T6 Torx Screwdriver.
Wedge the large plastic opening tool in the gap at the bottom between the top and bottom covers.
Apply a gentle downward force to separate the top cover from the bottom cover.
Wedge the large plastic opening tool in the gaps along each side to unhook the side clips.
Pull the bottom cover apart from the top cover.
Flip over the motherboard to reveal the keys
Carefully peal the mat from the motherboard.
3 autres ont terminé cette réparation.
