Aller au contenu principal
TOSHIBA Satellite E45W-C4200X Battery Replacement
Ce dont vous avez besoin
  1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: étape 1, image 1 de 2 TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: étape 1, image 2 de 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 2, image 1 de 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 2, image 2 de 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 3, image 1 de 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 3, image 2 de 2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 4, image 1 de 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 4, image 2 de 2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 5, image 1 de 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 5, image 2 de 2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X Battery Replacement: étape 6, image 1 de 1
    • Remove the battery from the laptop.
3 autres ont terminé cette réparation.
Un commentaire
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
Gabriel Meza - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 26
Total : 2,310
