Aller au contenu principal
TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement
Ce dont vous avez besoin
  1. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: étape 1, image 1 de 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement, Cooling Fan: étape 1, image 2 de 2
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 2, image 1 de 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 2, image 2 de 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 3, image 1 de 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 3, image 2 de 2
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 4, image 1 de 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 4, image 2 de 2
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 5, image 1 de 2 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 5, image 2 de 2
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 6, image 1 de 3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 6, image 2 de 3 TOSHIBA Satellite E45W-C4200X Cooling Fan Replacement: étape 6, image 3 de 3
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
Consider purchasing the entire H000085330 Toshiba Thermal Assembly E45DW-C4210. This includes the fan and heat transfer components assembled. As of January 2022, it is $14.00 on e-bay. This makes replacement much easier.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 376
