Aller au contenu principal
TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement
Ce dont vous avez besoin
  1. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: étape 1, image 1 de 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: étape 1, image 2 de 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: étape 2, image 1 de 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: étape 2, image 2 de 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommended that you start from a corner and run the tool along the edge
  3. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: étape 3, image 1 de 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: étape 3, image 2 de 2
    • Using a Phillips # 1 screwdriver, remove the three screws holding the bracket over the ports on the right side.
    • Remove the bracket.
  4. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: étape 4, image 1 de 3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: étape 4, image 2 de 3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: étape 4, image 3 de 3
    • Unplug the power cable harness from the motherboard.
    • Lift the power jack out of its slot in the top right corner.
    • Remove the cable.
Un commentaire
Thanks for this. Great help in sorting out my laptop.
Jack - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 647
