Aller au contenu principal
TOSHIBA Satellite E45W-C4200X Screen Replacement
Ce dont vous avez besoin
  1. TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: étape 1, image 1 de 2 TOSHIBA Satellite E45W-C4200X Screen Replacement, Screen: étape 1, image 2 de 2
    • Using a plastic opening tool, remove the plastic bar underneath the screen.
    • Use caution when removing the plastic bar to prevent cracking.
  2. TOSHIBA Satellite E45W-C4200X Screen Replacement: étape 2, image 1 de 1
    • Use the Phillips #1 screwdriver and remove the four screws at the bottom of the screen.
    • Be sure to store the screws in a safe place to prevent losing them.
  3. TOSHIBA Satellite E45W-C4200X Screen Replacement: étape 3, image 1 de 3 TOSHIBA Satellite E45W-C4200X Screen Replacement: étape 3, image 2 de 3 TOSHIBA Satellite E45W-C4200X Screen Replacement: étape 3, image 3 de 3
    • Use the blue plastic opening tool to start separating the plastic cover from the screen.
    • Once started, use the Jimmy to run along the edges to complete the separation.
    • Be sure to go very slow to avoid cracking the glass further and possibly cutting yourself.
    • The camera is still connecting the protective cover to the laptop; we recommend setting it on top of the keyboard.
  4. TOSHIBA Satellite E45W-C4200X Screen Replacement: étape 4, image 1 de 1
    • Remove the remaining screws that hold the screen in place using the Phillips #1 screwdriver.
    • Carefully lift out the screen and fold on its face.
    • The screen is still attached, do not pull away from the laptop.
  5. TOSHIBA Satellite E45W-C4200X Screen Replacement: étape 5, image 1 de 3 TOSHIBA Satellite E45W-C4200X Screen Replacement: étape 5, image 2 de 3 TOSHIBA Satellite E45W-C4200X Screen Replacement: étape 5, image 3 de 3
    • Disconnect the screen from the small circuit board.
    • Gently disconnect with even pressure on both sides to prevent damage.
    • The old screen has now been completely removed.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 26
Total : 2,114
