Aller au contenu principal
TRS-80 Color Computer Motherboard Replacement
Ce dont vous avez besoin
  1. TRS-80 Color Computer Motherboard Replacement, Outside Casing: étape 1, image 1 de 1
    • Flip the computer over.
    • Remove the two 24.1mm Phillips screws near the front of the case.
    • Remove the five 33.0 mm Phillips screws towards the back of the case.
  2. TRS-80 Color Computer Motherboard Replacement: étape 2, image 1 de 2 TRS-80 Color Computer Motherboard Replacement: étape 2, image 2 de 2
    • Carefully flip the computer right side up.
    • Lift off the top half of the case.
  3. TRS-80 Color Computer Motherboard Replacement, Keyboard: étape 3, image 1 de 2 TRS-80 Color Computer Motherboard Replacement, Keyboard: étape 3, image 2 de 2
    • Near the motherboard, gently pull the keyboard ribbon cable until it becomes free.
    • Lift the keyboard out of the case.
  4. TRS-80 Color Computer Motherboard Replacement, Motherboard: étape 4, image 1 de 3 TRS-80 Color Computer Motherboard Replacement, Motherboard: étape 4, image 2 de 3 TRS-80 Color Computer Motherboard Replacement, Motherboard: étape 4, image 3 de 3
    • Remove the nine 15.24 mm Phillips screws securing the motherboard in place.
    • When removing the spring door, make sure to keep the door closed.
  5. TRS-80 Color Computer Motherboard Replacement: étape 5, image 1 de 3 TRS-80 Color Computer Motherboard Replacement: étape 5, image 2 de 3 TRS-80 Color Computer Motherboard Replacement: étape 5, image 3 de 3
    • Remove the 5 jumper cables from the motherboard.
    • Once the jumper cables lift the motherboard up gently; it should lift out easily.
5 autres ont terminé cette réparation.
Andrew
Membre depuis le 01/23/11
529 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-24, Maness Winter 2011 Membre de l'équipe Cal Poly, Team 11-24, Maness Winter 2011
CPSU-MANESS-W11S11G24
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 4,065
