Aller au contenu principal
Tara Handle Replacement
  1. Tara Handle Replacement, Handle: étape 1, image 1 de 1
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Use a Tara tool to loosen the jam nuts on either side of the pump.
    • The bolts do not need to be loosened or removed, only the nuts need to be loosened.
  2. Tara Handle Replacement: étape 2, image 1 de 3 Tara Handle Replacement: étape 2, image 2 de 3 Tara Handle Replacement: étape 2, image 3 de 3
    • Unscrew the lock bolts about half an inch.
    • The bolts do not need to be removed from the base.
  3. Tara Handle Replacement: étape 3, image 1 de 2 Tara Handle Replacement: étape 3, image 2 de 2
    • Pull the plastic bushing and handle straight up out of the pump.
    • If the bushing doesn't come up, loosen the lock bolts further.
  4. Tara Handle Replacement: étape 4, image 1 de 2 Tara Handle Replacement: étape 4, image 2 de 2
    • Lift up the handle and riser main until the joint between the two is at a comfortable height to work on.
  5. Tara Handle Replacement: étape 5, image 1 de 3 Tara Handle Replacement: étape 5, image 2 de 3 Tara Handle Replacement: étape 5, image 3 de 3
    • Loosen the jam nut beneath the pump handle using the Tara tool.
  6. Tara Handle Replacement: étape 6, image 1 de 2 Tara Handle Replacement: étape 6, image 2 de 2
    • Unscrew the pump handle from the top of the riser main.
    • Make sure someone is tightly holding the lower portion of the riser main to prevent losing it down the well.
  7. Tara Handle Replacement: étape 7, image 1 de 2 Tara Handle Replacement: étape 7, image 2 de 2
    • Lift and remove the handle from the pump. Store the handle in a sanitary place to prevent contamination.
Sam Goldheart
Membre depuis le 10/18/12
471 732 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 538 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 246
