Aller au contenu principal
Tatung TAC-6G Heating Element Replacement
Ce dont vous avez besoin
  1. Tatung TAC-6G Heating Element Replacement, Heating Element: étape 1, image 1 de 1
    • Lift the lid and bowl from top of the device
    • Be sure device is not plugged in before beginning replacement of heating element
  2. Tatung TAC-6G Heating Element Replacement: étape 2, image 1 de 1
    • Turn the bowl upside down so that the three legs point upwards
  3. Tatung TAC-6G Heating Element Replacement: étape 3, image 1 de 2 Tatung TAC-6G Heating Element Replacement: étape 3, image 2 de 2
    • Remove the one 7 mm Phillips screw from the side of the brass panel.
  4. Tatung TAC-6G Heating Element Replacement: étape 4, image 1 de 2 Tatung TAC-6G Heating Element Replacement: étape 4, image 2 de 2
    • Remove the 6mm Phillips screw that holds the stainless plate.
  5. Tatung TAC-6G Heating Element Replacement: étape 5, image 1 de 3 Tatung TAC-6G Heating Element Replacement: étape 5, image 2 de 3 Tatung TAC-6G Heating Element Replacement: étape 5, image 3 de 3
    • Remove all four of the 15mm Phillips screws from all four of the brackets that hold the heating element in place
  6. Tatung TAC-6G Heating Element Replacement: étape 6, image 1 de 1
    • Using your hands, remove the heating plate that is on top of heating element.
  7. Tatung TAC-6G Heating Element Replacement: étape 7, image 1 de 1
    • Remove the 7mm Phillips screw that holds the white wire connected to the heating element.
  8. Tatung TAC-6G Heating Element Replacement: étape 8, image 1 de 1
    • Remove the 7mm Phillips screw that holds the white & maroon wires connected to the heating element.
  9. Tatung TAC-6G Heating Element Replacement: étape 9, image 1 de 1
    • Using, your hands, take out the heating element and replace it with a new one.
John David Mitchell
Membre depuis le 01/31/16
128 Réputation
1 tutoriel rédigé
Équipe
6 commentaires
where can I buy this heating element? Thanks.
dchang168 - Réponse
Tze Moh Yeo - Réponse
where to buy parts is the problem!!
William Co - Réponse
not sell tools here but parts, it’s easy to repair but parts is the problem
heat elements can be purchased in Taiwan. if you can read Chinese.
chengshiuntsai - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 47
Total : 4,152
