Aller au contenu principal
Tatung TAC-6G Light Element Replacement
Ce dont vous avez besoin
  1. Tatung TAC-6G Light Element Replacement, Light Element: étape 1, image 1 de 1
    • Start with the device standing upright.
  2. Tatung TAC-6G Light Element Replacement: étape 2, image 1 de 1
    • Remove the 11mm Phillips screw from below the power component panel.
  3. Tatung TAC-6G Light Element Replacement: étape 3, image 1 de 1
    • Pull the panel away from the rice cooker.
    • Remove the 9mm Phillips screw from behind the power component dashboard that is connected to the light plate.
  4. Tatung TAC-6G Light Element Replacement: étape 4, image 1 de 1
    • Pull the light plate from the power component panel.
  5. Tatung TAC-6G Light Element Replacement: étape 5, image 1 de 1
    • Flip the rice cooker device upside down.
  6. Tatung TAC-6G Light Element Replacement: étape 6, image 1 de 2 Tatung TAC-6G Light Element Replacement: étape 6, image 2 de 2
    • Remove the one 7mm Phillips screw from the side of the brass panel
    • Lift the brass plate off of the device and set it aside.
  7. Tatung TAC-6G Light Element Replacement: étape 7, image 1 de 1
    • Remove the 7mm Phillips screw holding the white and maroon colored wires that are connected to the heating element.
  8. Tatung TAC-6G Light Element Replacement: étape 8, image 1 de 1
    • Remove the 10mm Phillips screw that connects the white, blue and black wires to the white plastic piece in the corner of the device.
  9. Tatung TAC-6G Light Element Replacement: étape 9, image 1 de 1
    • Remove the 7mm Phillips screw that connects two white wires and one red wire to the heating "warm" switch.
  10. Tatung TAC-6G Light Element Replacement: étape 10, image 1 de 1
    • Using your hand, pull out the light plate with the maroon red and black wires.
  11. Tatung TAC-6G Light Element Replacement: étape 11, image 1 de 1
    • Replace the light plate dashboard.
Erin Charles
Membre depuis le 01/28/16
215 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Reverse the steps for reassembly.
Tom Anderson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 655
