Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Pièces
Aucune pièce spécifiée.
  1. Remove back cover by applying pressure and sliding up towards the top of the phone. Remove back cover by applying pressure and sliding up towards the top of the phone. Remove back cover by applying pressure and sliding up towards the top of the phone.
    • Remove back cover by applying pressure and sliding up towards the top of the phone.
  2. Remove the battery by lifting from slot on the right hand side. Remove the battery by lifting from slot on the right hand side.
    • Remove the battery by lifting from slot on the right hand side.
  3. Use Multimeter to test the voltage of the battery. Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Use Multimeter to test the voltage of the battery.
    • Put the black lead into ground slot of multimeter and the red lead into the V(ohm)mA slot.
    • Place the red and black leads to the two outside metal plate, each on opposite sides, on the battery as shown.
    • Check that the voltage displayed on the multimeter matches closely to the voltage defined on the battery. Normally 3.7 V.
Melinda Phan
Membre depuis le 17/04/2011
435 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 9-64, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-64, Walters Spring 2011
CPSU-WALTERS-S11S9G64
5 membres
9 tutoriels rédigés
Hello one the question was tablet not telephone and it's really vague how you guys explain these things you need to go to work on your site
Roger Slater - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 7
7 derniers jours : 14
30 derniers jours : 71
Total : 7,388
