Aller au contenu principal
Technostar Sandwich Toaster Thermal Fuse Replacement
Ce dont vous avez besoin
  1. Technostar Sandwich Toaster Thermal Fuse Replacement, Thermal Fuse: étape 1, image 1 de 1
    • Open the toaster.
    • Remove the four screws which attach the mold.
  2. Technostar Sandwich Toaster Thermal Fuse Replacement: étape 2, image 1 de 2 Technostar Sandwich Toaster Thermal Fuse Replacement: étape 2, image 2 de 2
    • Remove the mold to get access to the heating coil.
  3. Technostar Sandwich Toaster Thermal Fuse Replacement: étape 3, image 1 de 1
    • Find the thermofuse.
  4. Technostar Sandwich Toaster Thermal Fuse Replacement: étape 4, image 1 de 2 Technostar Sandwich Toaster Thermal Fuse Replacement: étape 4, image 2 de 2
    • Cut the two wires that connect to the thermal fuse.
  5. Technostar Sandwich Toaster Thermal Fuse Replacement: étape 5, image 1 de 2 Technostar Sandwich Toaster Thermal Fuse Replacement: étape 5, image 2 de 2
    • Align the thermal fuse with the open wires.
    • Put the spade connectors over the wires.
    • Using pliers, clamp the wires together.
  6. Technostar Sandwich Toaster Thermal Fuse Replacement: étape 6, image 1 de 1
    • Replace the molds.
    • Replace the four screws which attach the mold.
Ligne d'arrivée
4 autres ont terminé cette réparation.
2 commentaires
where did u find the replacement fuse? I need a thermal fuse for Breville BSG520XL Panini Duo Grill
mortaz - Réponse
how do i test that the reason that my toaster is not working is actually the thermal fuse?
itzsabag - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 37
Total : 3,995
