Aller au contenu principal
Teddy Bear Nose Replacement
Ce dont vous avez besoin
  1. Teddy Bear Nose Replacement, Nose: étape 1, image 1 de 2 Teddy Bear Nose Replacement, Nose: étape 1, image 2 de 2
    • Rip out about five inches of stitches from around the bear's snout.
  2. Teddy Bear Nose Replacement: étape 2, image 1 de 2 Teddy Bear Nose Replacement: étape 2, image 2 de 2
    • Remove stuffing from around the bear's snout.
  3. Teddy Bear Nose Replacement: étape 3, image 1 de 1
    • Flip the fabric of the snout inside out to expose the back of the plastic nose.
  4. Teddy Bear Nose Replacement: étape 4, image 1 de 2 Teddy Bear Nose Replacement: étape 4, image 2 de 2
    • Remove the plastic backing of the teddy bear's nose (if it's still there). You may have to use pliers.
  5. Teddy Bear Nose Replacement: étape 5, image 1 de 1
    • Pull the nose out of the front of the teddy bear’s face.
  6. Teddy Bear Nose Replacement: étape 6, image 1 de 1
    • Push the front of the new nose through the existing hole in the teddy bear’s face.
  7. Teddy Bear Nose Replacement: étape 7, image 1 de 1
    • Attach the nose backing on the inside of the teddy bear’s nose.
  8. Teddy Bear Nose Replacement: étape 8, image 1 de 1
    • Restuff the teddy bear’s nose with the stuffing you took out.
    • You may need to add more stuffing if the bear’s nose looks flat or deflated.
  9. Teddy Bear Nose Replacement: étape 9, image 1 de 1
    • Thread the needle with about 18 inches of thread the same color as the bear's fur or stitches.
  10. Teddy Bear Nose Replacement: étape 10, image 1 de 3 Teddy Bear Nose Replacement: étape 10, image 2 de 3 Teddy Bear Nose Replacement: étape 10, image 3 de 3
    • Sew the teddy bear’s face using a whip stitch until the opening is completely closed.
    • For help with sewing a whip stitch, follow this guide: Comment coudre au point de surjet.
  11. Teddy Bear Nose Replacement: étape 11, image 1 de 2 Teddy Bear Nose Replacement: étape 11, image 2 de 2
    • Once the face is completely sewn shut, knot the end of the thread, and cut off the excess.
Ligne d'arrivée
Nazib Khan
Membre depuis le 09/28/21
193 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 32
30 derniers jours : 113
Total : 4,006
