Aller au contenu principal
Teddy Bear String Smile Replacement
Ce dont vous avez besoin
  1. Teddy Bear String Smile Replacement, String Smile: étape 1, image 1 de 1
    • Using the scissors, cut away the existing string smile from the teddy bear.
  2. Teddy Bear String Smile Replacement: étape 2, image 1 de 2 Teddy Bear String Smile Replacement: étape 2, image 2 de 2
    • Using a water-soluble marker, test a small patch on the teddy bear in the area you will be replacing the smile.
    • Once you have tested the patch and made sure the marker washes off the fabric, sketch the smile in the area you desire.
  3. Teddy Bear String Smile Replacement: étape 3, image 1 de 2 Teddy Bear String Smile Replacement: étape 3, image 2 de 2
    • Take one end of the thread and slide it through the thin hole, or eye, at the top of the needle.
    • Once the needle is threaded with your desired length of string (the length of the smile plus a bit more), tie both ends of the string together in a knot.
  4. Teddy Bear String Smile Replacement: étape 4, image 1 de 2 Teddy Bear String Smile Replacement: étape 4, image 2 de 2
    • At an angle, stick the needle through the back of the ear.
    • Pull the needle through a stitch-length away from the corner of your drawn on mouth.
    • Keep pulling until you feel the tug of the knot on the inside of the smile.
  5. Teddy Bear String Smile Replacement: étape 5, image 1 de 1
    • Stick the needle back through the hole you just made and pull it out a stitch-length away; this starts the backstitch.
    • You will be using the drawn on pattern as a reference.
  6. Teddy Bear String Smile Replacement: étape 6, image 1 de 1
    • Continue the backstitch across the smile area until the smile is complete.
  7. Teddy Bear String Smile Replacement: étape 7, image 1 de 3 Teddy Bear String Smile Replacement: étape 7, image 2 de 3 Teddy Bear String Smile Replacement: étape 7, image 3 de 3
    • Stick the needle through the second-to-last stitch.
    • Pull the needle through, diagonally, and pull it out behind the ear that you started with. This will leave a “tail” hanging from behind the ear.
  8. Teddy Bear String Smile Replacement: étape 8, image 1 de 3 Teddy Bear String Smile Replacement: étape 8, image 2 de 3 Teddy Bear String Smile Replacement: étape 8, image 3 de 3
    • At the longest part of the thread, cut the needle away.
    • Tie the two pieces of thread together into a knot against the back of the ear.
    • Cut away the remaining thread.
And now you’re all set! You get to enjoy more moments with your sentimental piece!
2 autres ont terminé cette réparation.
Khadijah
Membre depuis le 07/24/20
214 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team S1-G17, Cardinal Summer 2020 Membre de l'équipe UW Tacoma, Team S1-G17, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G17
1 membre
3 tutoriels rédigés
1 commentaire de tutoriel
Please are you able to tell me the brand of this monkey? I’ve been searching for months for this as a replacement for my daughters lost monkey
Kirsty Thomas-Eardley - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 12
Total : 1,636
