Aller au contenu principal
Teddy Ruxpin Arm Button Replacement
Ce dont vous avez besoin
  1. Teddy Ruxpin Arm Button Replacement, Battery: étape 1, image 1 de 2 Teddy Ruxpin Arm Button Replacement, Battery: étape 1, image 2 de 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Arm Button Replacement: étape 2, image 1 de 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Arm Button Replacement: étape 3, image 1 de 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Arm Button Replacement, Arms: étape 4, image 1 de 3 Teddy Ruxpin Arm Button Replacement, Arms: étape 4, image 2 de 3 Teddy Ruxpin Arm Button Replacement, Arms: étape 4, image 3 de 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Arm Button Replacement: étape 5, image 1 de 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Arm Button Replacement: étape 6, image 1 de 3 Teddy Ruxpin Arm Button Replacement: étape 6, image 2 de 3 Teddy Ruxpin Arm Button Replacement: étape 6, image 3 de 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Arm Button Replacement: étape 7, image 1 de 2 Teddy Ruxpin Arm Button Replacement: étape 7, image 2 de 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Arm Button Replacement: étape 8, image 1 de 2 Teddy Ruxpin Arm Button Replacement: étape 8, image 2 de 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Arm Button Replacement: étape 9, image 1 de 1
    • Unplug the arms from the main body.
3 autres ont terminé cette réparation.
Lauren
Membre depuis le 01/23/20
214 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G5, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 membres
7 tutoriels rédigés
3 commentaires
All you need are screwdrivers? The most important part is left out! New buttons? Where, how?
embalmerjules - Réponse
And how do you replace it?! This just says how to take out old buttons!
Summer-Lynn Morente - Réponse
So has anyone figured out how to replace the button?
knrobinson83 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 27
Total : 831
