Aller au contenu principal
Teddy Ruxpin Mouth Replacement
Ce dont vous avez besoin
  1. Teddy Ruxpin Mouth Replacement, Battery: étape 1, image 1 de 2 Teddy Ruxpin Mouth Replacement, Battery: étape 1, image 2 de 2
    • Remove the vest covering the back of the bear.
    • Orient the bear with his back facing upwards and unscrew the single Phillips #2 screw.
    • Captured screws will stay in place, no need to worry about losing this one!
  2. Teddy Ruxpin Mouth Replacement: étape 2, image 1 de 1
    • Pull the tab outward to remove the protective plate for the batteries.
  3. Teddy Ruxpin Mouth Replacement: étape 3, image 1 de 1
    • Remove all four AA batteries by pushing the positive end down and pulling the battery out toward yourself.
  4. Teddy Ruxpin Mouth Replacement, Arms: étape 4, image 1 de 3 Teddy Ruxpin Mouth Replacement, Arms: étape 4, image 2 de 3 Teddy Ruxpin Mouth Replacement, Arms: étape 4, image 3 de 3
    • Cut the orange shirt and zip tie.
    • Remove the zip tie.
  5. Teddy Ruxpin Mouth Replacement: étape 5, image 1 de 1
    • Cut across the back seam of the head of the bear along the arrow.
    • This damages the bear's exterior and will require resewing.
  6. Teddy Ruxpin Mouth Replacement: étape 6, image 1 de 3 Teddy Ruxpin Mouth Replacement: étape 6, image 2 de 3 Teddy Ruxpin Mouth Replacement: étape 6, image 3 de 3
    • Remove the interior of the doll.
    • Peel the outer layer around the head of the bear and forcefully pry off the face of the bear from the outside layer of the bear.
    • This will be difficult and require significant force, but do not fear about breaking the doll at this stage.
  7. Teddy Ruxpin Mouth Replacement: étape 7, image 1 de 2 Teddy Ruxpin Mouth Replacement: étape 7, image 2 de 2
    • Extract each arm button.
    • Pull on the stuffing of the bear and not the wire to remove the arm button.
  8. Teddy Ruxpin Mouth Replacement: étape 8, image 1 de 2 Teddy Ruxpin Mouth Replacement: étape 8, image 2 de 2
    • Pull off the rest of the outside layer of the bear.
  9. Teddy Ruxpin Mouth Replacement: étape 9, image 1 de 1
    • Unplug the arms from the main body.
  10. Teddy Ruxpin Mouth Replacement, Housing Cover: étape 10, image 1 de 3 Teddy Ruxpin Mouth Replacement, Housing Cover: étape 10, image 2 de 3 Teddy Ruxpin Mouth Replacement, Housing Cover: étape 10, image 3 de 3
    • Unscrew the eleven circled 12.5mm Phillips #1 screws.
    • Remove the top of the housing to access the electronics inside.
  11. Teddy Ruxpin Mouth Replacement, Eyes: étape 11, image 1 de 1
    • Using a Phillips #1 screwdriver, remove the two 12.5mm screws connecting the eyes to the rest of the mechanism.
  12. Teddy Ruxpin Mouth Replacement: étape 12, image 1 de 2 Teddy Ruxpin Mouth Replacement: étape 12, image 2 de 2
    • Unplug the two sets of wires connected to the back of the eyes by using moderate to high force.
  13. Teddy Ruxpin Mouth Replacement: étape 13, image 1 de 1
    • Once those wires are disconnected, desolder the wires connected from the eye motherboard.
  14. Teddy Ruxpin Mouth Replacement, Mouth: étape 14, image 1 de 2 Teddy Ruxpin Mouth Replacement, Mouth: étape 14, image 2 de 2
    • Remove five 12.5mm Phillips #1 screws.
    • Pull the mouth mechanism out of the shell.
  15. Teddy Ruxpin Mouth Replacement: étape 15, image 1 de 2 Teddy Ruxpin Mouth Replacement: étape 15, image 2 de 2
    • Unscrew the last 12.5mm Phillips #1 screw holding the mouth together
    • Open the mouth mechanism
Jayin Patel
Membre depuis le 01/23/20
394 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S18-G5, White Winter 2020 Membre de l'équipe Cal Poly, Team S18-G5, White Winter 2020
CPSU-WHITE-W20S18G5
4 membres
7 tutoriels rédigés
3 commentaires
His mouth and nose fell out leaving a hole in his face. How do i fix it or is the repair shop local? He is 30 years old.
rrhall559 - Réponse
Mouth and nose fellout
rrhall559 - Réponse
World of wonder made it and they aren’t in business anymore
rrhall559 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 28
Total : 946
