Aller au contenu principal
Teenage Engineering OP-1 Battery Replacement
Ce dont vous avez besoin
  1. Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: étape 1, image 1 de 3 Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: étape 1, image 2 de 3 Teenage Engineering OP-1 Battery Replacement, Remove Back Panel: étape 1, image 3 de 3
    • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
    • Lift the back panel and remove it. The Connector Board is revealed.
    • Disconnect the flex connector by lifting it up with a spudger.
  2. Teenage Engineering OP-1 Battery Replacement, key removal: étape 2, image 1 de 3 Teenage Engineering OP-1 Battery Replacement, key removal: étape 2, image 2 de 3 Teenage Engineering OP-1 Battery Replacement, key removal: étape 2, image 3 de 3
    • To get to the screws beneath the keyboard you need to take some keys off. You can use either an opening tool or an opening pick. The first picture shows how it should look like with all the necessary keys off (12 in total).
    • The four longer keys from the fingerboard are to be handled from the left side to get them off.
    • The eight smaller keys need to be levered from the bottom up.
  3. Teenage Engineering OP-1 Battery Replacement, removing scissors mechanisms: étape 3, image 1 de 2 Teenage Engineering OP-1 Battery Replacement, removing scissors mechanisms: étape 3, image 2 de 2
    • The scissor mechanism of the eight small keys are obstructing the underlying screws.
    • By using again an opening tool or opening pick these can be snapped off easily.
    • When reassembling be sure to place them in with the correct side facing upwards.
  4. Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: étape 4, image 1 de 3 Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: étape 4, image 2 de 3 Teenage Engineering OP-1 Battery Replacement, unscrew keyboard: étape 4, image 3 de 3
    • Loosen those 12 screws with a Phillips #00 screwdriver.
    • Then just pull off the four rotary knobs and the volume knob.
    • Now it is possible to slightly lift the keyboard and set it back.
  5. Teenage Engineering OP-1 Battery Replacement, battery removal: étape 5, image 1 de 3 Teenage Engineering OP-1 Battery Replacement, battery removal: étape 5, image 2 de 3 Teenage Engineering OP-1 Battery Replacement, battery removal: étape 5, image 3 de 3
    • Carefully pull out the connector cable from the connector board and bend it out of the way.
    • Disconnect the battery with a spudger. The connector needs to be lifted up and not being pulled to the side.
    • Now you can pry out the battery which is glued in with double sided adhesive tape.
13 autres ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 03/31/14
124 016 Réputation
189 tutoriels rédigés
Équipe
Tobias Isakeit - Repairability Engineer Membre de l'équipe Tobias Isakeit - Repairability Engineer
Business
1 membre
1 131 tutoriels rédigés
41 commentaires
This is great. What type of battery is the replacement?? thanks!
TrustNoShadows - Réponse
Hi, thanks for the question. I added another picture and put some information in the introduction.
Tobias Isakeit -
hey, thanks for this! is the battery plug simple JST or do I need to get something specific?
lfsaw - Réponse
Yes, a simple JST plug (probably type ACH)
Tobias Isakeit -
Thanks for posting these instructions! I'm having trouble finding a battery that matches the one in the picture (unless I want to buy 1000 of them from Alibaba). Would this work?
http://www.ebay.com/itm/3-7V-1800mAh-Rec...
Dimensions are:
thick:3mm
wide:60mm
length:70mm
Clarke Robinson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 97
30 derniers jours : 588
Total : 39,088
