Aller au contenu principal
Teenage Engineering OP-1 Connector Board Replacement
Ce dont vous avez besoin
  1. Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: étape 1, image 1 de 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: étape 1, image 2 de 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Back Panel: étape 1, image 3 de 3
    • Open the back panel by using a Jimmy on the side of the panel. Be careful not to damage the OP-1 coating.
    • Lift the back panel and remove it. The Connector Board is revealed.
  2. Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: étape 2, image 1 de 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: étape 2, image 2 de 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: étape 2, image 3 de 3
    • Disconnect the flex connector by lifting it up with a spudger.
    • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
    • Take out the connector board.
    • Make sure to keep the black rubber pad underneath the board.
  3. Teenage Engineering OP-1 Connector Board Replacement: étape 3, image 1 de 2 Teenage Engineering OP-1 Connector Board Replacement: étape 3, image 2 de 2
    • Don't forget the cover for the on/off switch.
    • Simply take it off from the old board and transfer it to the new board.
45 autres ont terminé cette réparation.
teenage engineering
Membre depuis le 10/23/13
1 077 Réputation
2 tutoriels rédigés
Équipe
Teenage Engineering Membre de l'équipe Teenage Engineering
Community
3 membres
7 tutoriels rédigés
42 commentaires
Veeery useful , thank you !
mouchtouris alexandre - Réponse
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Shawn Ivie - Réponse
Got the back panel off finally but my connector board won't come out.
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
J-J -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 81
30 derniers jours : 302
Total : 46,261
