Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to replace the volume potentiometer of your OP-Z.
In case the defect was caused by a drop then the volume knob was probably damaged too. This guide will also show how to replace the knob which can be purchased separately.
  1. Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip. There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is. There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity). If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and  gently tug on one of them.
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Remove the bottom plate including the rubber feet.
    • Remove the bottom plate including the rubber feet.
  4. Use your fingernail or a spudger to lift the battery on the right side where the notch is. Use your fingernail or a spudger to lift the battery on the right side where the notch is.
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Remove the battery. When installing the new battery make sure you put it in contact side first.
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Use your finger or a spudger to push up on the small tab on the bottom of the module. Lift the module up and out of its recess bottom first.
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Remove the module.
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Remove the five Torx T4 screws.
    • Remove the five Torx T4 screws.
  9. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  10. Place a spudger in the cutout of the extension module to lift the midframe. Be careful not to damage the highway flex cable underneath.
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  11. Flip the midframe over to gain access to the flex cable connector underneath. Flip the midframe over to gain access to the flex cable connector underneath. Flip the midframe over to gain access to the flex cable connector underneath.
    • Flip the midframe over to gain access to the flex cable connector underneath.
  12. Use the flat end of a spudger to disconnect the flex cable from the front panel assembly. Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  13. Use a spudger to disconnect the highway flex cable from the DSP board. Use a spudger to disconnect the highway flex cable from the DSP board.
    • Use a spudger to disconnect the highway flex cable from the DSP board.
  14. Use the spudger to disconnect the flex cable from the encoder board. Use the spudger to disconnect the flex cable from the encoder board.
    • Use the spudger to disconnect the flex cable from the encoder board.
  15. Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board. The connector is slightly glued down. The connector is slightly glued down.
    • Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
    • The connector is slightly glued down.
  16. Insert the pointy end of the spudger into the line-out jack and lever it up carefully. The jack connector might sit tight and is slightly glued down. The jack connector might sit tight and is slightly glued down.
    • Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
    • The jack connector might sit tight and is slightly glued down.
  17. The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath. A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here. A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
    • The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
    • A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
  18. Peel the highway flex cable off the midframe and remove it. Peel the highway flex cable off the midframe and remove it. Peel the highway flex cable off the midframe and remove it.
    • Peel the highway flex cable off the midframe and remove it.
  19. Use one arm of a tweezer to lift the small black flap of the ZIF connector. Use one arm of a tweezer to lift the small black flap of the ZIF connector.
    • Use one arm of a tweezer to lift the small black flap of the ZIF connector.
  20. Use a pair of flat nose tweezers to pull the small flex cable up and out out the ZIF connector. When reassembling make sure to insert the flex cable all the way.
    • Use a pair of flat nose tweezers to pull the small flex cable up and out out the ZIF connector.
    • When reassembling make sure to insert the flex cable all the way.
  21. Grab the volume knob with your fingers or a pair of pliers and pull it off its axle. Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
    • Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
  22. Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout. The volume pot is slightly glued down.
    • Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout.
    • The volume pot is slightly glued down.
  23. Remove the volume potentiometer.
    • Remove the volume potentiometer.
Tobias Isakeit
Membre depuis le 31/03/2014
63 653 Réputation
133 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
111 membres
10 704 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 72
