Aller au contenu principal
Teenage Engineering OP-Z Volume Potentiometer Replacement
Ce dont vous avez besoin
  1. Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: étape 1, image 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: étape 1, image 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement, Back Cover: étape 1, image 3 de 3
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 2, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 2, image 2 de 2
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 3, image 1 de 1
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: étape 4, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Battery: étape 4, image 2 de 2
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 5, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 5, image 2 de 2
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: étape 6, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Expansion Module: étape 6, image 2 de 2
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 7, image 1 de 1
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Volume Potentiometer Replacement, Midframe: étape 8, image 1 de 1
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 9, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 9, image 2 de 2
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 10, image 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 10, image 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 10, image 3 de 3
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 11, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 11, image 2 de 2
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: étape 12, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Highway Flex Cable: étape 12, image 2 de 2
    • Use a spudger to disconnect the highway flex cable from the DSP board.
  13. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 13, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 13, image 2 de 2
    • Use the spudger to disconnect the flex cable from the encoder board.
  14. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 14, image 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 14, image 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 14, image 3 de 3
    • Slowly pry the USB-C connector out of its recess. Use the flat end of a spudger on the small nib on the USB-C board.
    • The connector is slightly glued down.
  15. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 15, image 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 15, image 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 15, image 3 de 3
    • Insert the pointy end of the spudger into the line-out jack and lever it up carefully.
    • The jack connector might sit tight and is slightly glued down.
  16. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 16, image 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 16, image 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 16, image 3 de 3
    • The highway flex cable is slightly adhered to the midframe. To remove it, gently push it out from underneath.
    • A small transparent part may pop out. This is the light guide for the bluetooth indicator. Just hinge it back onto the midframe as seen here.
  17. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 17, image 1 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 17, image 2 de 3 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 17, image 3 de 3
    • Peel the highway flex cable off the midframe and remove it.
  18. Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: étape 18, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement, Volume Pot: étape 18, image 2 de 2
    • Use one arm of a tweezer to lift the small black flap of the ZIF connector.
  19. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 19, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 19, image 2 de 2
    • Use a pair of flat nose tweezers to pull the small flex cable up and out out the ZIF connector.
    • When reassembling make sure to insert the flex cable all the way.
  20. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 20, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 20, image 2 de 2
    • Grab the volume knob with your fingers or a pair of pliers and pull it off its axle.
  21. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 21, image 1 de 2 Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 21, image 2 de 2
    • Use a spudger to lever up the axle of the volume potentiometer. This way it will clear the frame’s cutout.
    • The volume pot is slightly glued down.
  22. Teenage Engineering OP-Z Volume Potentiometer Replacement: étape 22, image 1 de 1
    • Remove the volume potentiometer.
Tobias Isakeit
Membre depuis le 03/31/14
117 598 Réputation
188 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 534 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
Total : 1,121
