Aller au contenu principal
Tektro Aires Disc Brakes Brake Pad Replacement
Ce dont vous avez besoin
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: étape 1, image 1 de 1
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: étape 2, image 1 de 2 Tektro Aires Disc Brakes Brake Pad Replacement: étape 2, image 2 de 2
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: étape 3, image 1 de 1
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: étape 4, image 1 de 1
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: étape 5, image 1 de 1
    • Remove the brake pads by pulling on them and realesing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: étape 6, image 1 de 1
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
2 autres ont terminé cette réparation.
Randall Eakes
Membre depuis le 10/26/21
193 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 39
30 derniers jours : 240
Total : 3,744
