Aller au contenu principal
Tello Quadcopter Propeller Replacement
Ce dont vous avez besoin
  1. Tello Quadcopter Propeller Replacement, Propeller: étape 1, image 1 de 1
    • Identify the propeller being replaced.
    • Gather the required materials.
  2. Tello Quadcopter Propeller Replacement: étape 2, image 1 de 2 Tello Quadcopter Propeller Replacement: étape 2, image 2 de 2
    • Next, remove the battery by grasping each side and pulling it out.
  3. Tello Quadcopter Propeller Replacement: étape 3, image 1 de 3 Tello Quadcopter Propeller Replacement: étape 3, image 2 de 3 Tello Quadcopter Propeller Replacement: étape 3, image 3 de 3
    • Remove the propeller by inserting the provided tool between the propeller and drone.
    • Needle nose pliers can be used instead. Use the pliers to grasp directly below the propeller.
    • Gently lift the propeller from the socket using your choice of tool.
  4. Tello Quadcopter Propeller Replacement: étape 4, image 1 de 3 Tello Quadcopter Propeller Replacement: étape 4, image 2 de 3 Tello Quadcopter Propeller Replacement: étape 4, image 3 de 3
    • After removing the old propeller, orient the new propeller over the empty socket.
    • Insert a new propeller by applying force. The propeller should snap into place.
You have successfully completed replacing the damaged propellor.
Cody White
Membre depuis le 10/08/20
109 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 30
Total : 1,943
