Aller au contenu principal
Texas Instruments TI-30X IIS Battery Replacement
Ce dont vous avez besoin
  1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: étape 1, image 1 de 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: étape 1, image 2 de 3 Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: étape 1, image 3 de 3
    • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
    • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
  2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: étape 2, image 1 de 2 Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: étape 2, image 2 de 2
    • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
    • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
  3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: étape 3, image 1 de 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: étape 3, image 2 de 3 Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: étape 3, image 3 de 3
    • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
    • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
  4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: étape 4, image 1 de 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: étape 4, image 2 de 3 Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: étape 4, image 3 de 3
    • With the rear case off, the battery is exposed and accessible.
    • Using a pointed tool, slide the battery out of its terminal towards the near edge.
    • Once the battery is protruding from the contacts, remove it with your fingers.
  5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: étape 5, image 1 de 1
    • Properly dispose of the old battery.
    • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
    • Following the previous steps in the reverse order to reassemble the calculator.
20 autres ont terminé cette réparation.
Ryan
Membre depuis le 03/01/15
515 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 15
7 derniers jours : 56
30 derniers jours : 424
Total : 32,848
