Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Texas Instruments TI-83 Plus Individual Keys Replacement
Ce dont vous avez besoin
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: étape 1, image 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: étape 1, image 2 de 2
      • Remove the battery cover.
      • Remove the AAA batteries from the calculator.
      Demander à FixBot
      Ajouter un commentaire
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: étape 2, image 1 de 1
      • Remove the 5mm Philips #00 screw holding backup battery cover.
      • Remove the backup battery cover.
      Demander à FixBot
    3. Texas Instruments TI-83 Plus Individual Keys Replacement: étape 3, image 1 de 1
      • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
      • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
      Demander à FixBot
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: étape 4, image 1 de 1
      • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
      Demander à FixBot
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: étape 5, image 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement: étape 5, image 2 de 2
      • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
      Demander à FixBot
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: étape 6, image 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: étape 6, image 2 de 2
      • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
      • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
      Demander à FixBot
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: étape 7, image 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement: étape 7, image 2 de 2
      • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
      Demander à FixBot
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: étape 8, image 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: étape 8, image 2 de 2
      • Remove light gray rubber keyboard mat.
      • Keep your calculator face down to ensure the individual keys do not fall out.
      Demander à FixBot
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: étape 9, image 1 de 1
      • Clean the contacts on the keyboard with a soft cloth.
      Demander à FixBot
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: étape 10, image 1 de 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: étape 10, image 2 de 2
      Outil utilisé dans cette étape :
      • Use tweezers to remove one key at a time.
      • Be sure to keep them organized if you are taking out multiple keys.
      Demander à FixBot
2 autres ont terminé cette réparation.
Jared
Membre depuis le 10/02/12
156 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 18-37, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 membres
23 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 61
Total : 5,492
