Aller au contenu principal
The Beatles Rock Band Hofner Bass Strummer Bar Replacement
Ce dont vous avez besoin
  1. The Beatles Rock Band Hofner Bass Strummer Bar Replacement, Back Plate: étape 1, image 1 de 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Strummer Bar Replacement: étape 2, image 1 de 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Strummer Bar Replacement: étape 3, image 1 de 2 The Beatles Rock Band Hofner Bass Strummer Bar Replacement: étape 3, image 2 de 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Strummer Bar Replacement, Strummer Bar: étape 4, image 1 de 1
    • Use a J1 Phillips head screwdriver to remove the four 10mm screws at the corners of the black casing.
  5. The Beatles Rock Band Hofner Bass Strummer Bar Replacement: étape 5, image 1 de 1
    • Remove the connection from the board, so that the strummer is no longer connected.
    • Carefully take the strummer out of the guitar, now that it is no longer connected.
    • Now the strummer is completely removed.
Jacob
Membre depuis le 01/25/17
601 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 8-4, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 membres
6 tutoriels rédigés
Un commentaire
How/where do I purshase a new strummer bar?
Peter Grav - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 1,036
