Aller au contenu principal
The Beatles Rock Band Hofner Bass Whammy Bar Replacement
Ce dont vous avez besoin
  1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Back Plate: étape 1, image 1 de 1
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: étape 2, image 1 de 1
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: étape 3, image 1 de 2 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: étape 3, image 2 de 2
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Whammy Bar: étape 4, image 1 de 1
    • Use J1 Phillips screwdriver to remove the four 10mm screws on the whammy bars black cover.
  5. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: étape 5, image 1 de 1
    • Remove the black cover.
    • Now the white whammy bar underneath is visible.
  6. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: étape 6, image 1 de 2 The Beatles Rock Band Hofner Bass Whammy Bar Replacement: étape 6, image 2 de 2
    • Use a J1 Philips head screwdriver to remove one 10mm screw.
    • This will unscrew the electrical connection between the whammy bar and the blue circuit board.
    • Remove the electrical connector.
  7. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: étape 7, image 1 de 1
    • Remove the whammy bar, since nothing should be connecting to the guitar anymore.
Jacob
Membre depuis le 01/25/17
601 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 8-4, Banghart Winter 2017 Membre de l'équipe Cal Poly, Team 8-4, Banghart Winter 2017
CPSU-BANGHART-W17S8G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 659
