Aller au contenu principal
The Claw Battery Replacement
Ce dont vous avez besoin
  1. The Claw Battery Replacement, Batteries: étape 1, image 1 de 1
    • Hold The Claw machine upright so that the controls are facing you.
  2. The Claw Battery Replacement: étape 2, image 1 de 1
    • Turn the device upside down keeping the controls facing in your direction.
  3. The Claw Battery Replacement: étape 3, image 1 de 1
    • Locate the battery compartment door on the bottom cover of The Claw.
    • Loosen the screw from the battery compartment door with your phillips head screwdriver.
  4. The Claw Battery Replacement: étape 4, image 1 de 1
    • Open the door and insert the 3 D-cell batteries using the correct configuration that is labeled on the inside of the compartment.
    • If the batteries are not placed in the right configuration the device will not operate. make sure to identify positive and negative sides of the battery and follow the configuration on the device.
Alain Pierre
Membre depuis le 03/22/16
1 188 Réputation
9 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-8, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 4-8, Catania Spring 2016
UMASSD-CATANIA-S16S4G8
3 membres
18 tutoriels rédigés
Un commentaire
daiobn ht45o9iyjugggjvj nvj vnv jnkrfdoelcbigvfcofrbbvfgb4vg3rcf2edebb
Jennifer Mateo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 29
Total : 3,039
