Aller au contenu principal
The Claw Circuit Board Replacement
Ce dont vous avez besoin
  1. The Claw Circuit Board Replacement, Bottom Cover: étape 1, image 1 de 1
    • Place The Claw in upright position with controls facing you.
  2. The Claw Circuit Board Replacement: étape 2, image 1 de 1
    • Gently flip The Claw machine upside down with the controls facing you.
  3. The Claw Circuit Board Replacement: étape 3, image 1 de 1
    • Remove all ten screws from the bottom cover using a Phillips #1 screwdriver.
    • You will need a screwdriver with a long thin neck to fit in the screw holes.
  4. The Claw Circuit Board Replacement: étape 4, image 1 de 2 The Claw Circuit Board Replacement: étape 4, image 2 de 2
    • Slide the bottom cover off to the side.
    • Do not completely remove bottom cover as it is still connected to wires.
  5. The Claw Circuit Board Replacement: étape 5, image 1 de 1
    • Complete removal of the bottom cover is not necessary, however if you feel you need to take the cover completely off the machine to complete your task it can be done by the following process.
    • You will need to cut the two green wires attached to the music player.
    • Then you will need to cut the white wire that leads to the battery compartment.
    • Finally you will need to cut the black wire leading to the battery compartment as well.
    • The complete removal of the bottom cover requires the cutting and soldering of wires. For help with soldering reference: Comment souder et dessouder des connexions.
  6. The Claw Circuit Board Replacement, Circuit Board: étape 6, image 1 de 1
    • Once you have removed the bottom cover you should have clear access to the circuit board.
    • Locate the circuit board in the bottom of The Claw machine.
  7. The Claw Circuit Board Replacement: étape 7, image 1 de 1
    • Locate the screws that hold the circuit board in place.
  8. The Claw Circuit Board Replacement: étape 8, image 1 de 1
    • Be sure to turn off the device and remove the batteries before reaching into the device with your hands or any metal tools.
    • Using a Phillips #1 screwdriver, remove the four 6mm that hold the circuit board in place.
    • You will also need to cut all of the wires leading to the circuit board to completely remove it.
  9. The Claw Circuit Board Replacement: étape 9, image 1 de 1
    • Remove the circuit board.
    • The removal of the circuit board requires the cutting of existing wires and soldering new wires to the new board. For help with soldering reference: Comment souder et dessouder des connexions.
2 autres ont terminé cette réparation.
Alain Pierre
Membre depuis le 03/22/16
1 188 Réputation
9 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-8, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 4-8, Catania Spring 2016
UMASSD-CATANIA-S16S4G8
3 membres
18 tutoriels rédigés
6 commentaires
I accidentally cut the wires where the motors are and now can not figure out which go where, is there a diagram or drawling of where each wire goes?
Dyn4mic Universe - Réponse
Did you ever find a diagram for this? I would like to have one also….
Nathan Riffel -
Does anybody know where to get the replacement switches for these?
Bill B. - Réponse
Same. I am in need of the replacements as well.
Allison Rousseau -
Me too. L/R switch doesn't work need to replace it.
Johnny Annon -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 99
Total : 6,017
