Il est possible que cette traduction ne reflète pas les dernières mises à jour du tutoriel source. Aidez à mettre à jour la traduction ou bien consultez le tutoriel source.
Introduction
Utilisez ce guide pour remplacer les lumières de votre Logitech G910.
Ce dont vous avez besoin
Retournez le clavier et dévissez les vis arrière "15".
doesn’t mention unscrewing the screws under the palmrest to remove the plastic under the palmrest to get at the back screws underneath
Libère la partie avant.
Step 2a: remove the 7 screws on the back of the keyboard towards the top (including 2 under the arx Dock)
Step 2b: remove the 8 screws from the back of the wrist rest
Step 2c: remove the back of the wrist rest
Step 2d: I've already removed 15 screws as per this guide, but there are 6 more under the wrist rest, should these be removed?
Step 2e: somehow remove the plastic trim that comprises the rest of the wrist rest and the keyboard surround. This is where I'm stuck, I can't remove this.
This guide to disassembly basically is “step 1: just disassemble the keyboard”
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
5 autres ont terminé cette réparation.
Merci à ces traducteurs :
33%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
3 commentaires
So what do I do after I take apart my keyboard?
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
