Introduction
If by troubleshooting you have determined that your USB cord is defective, you will need to replace it. This guide will demonstrate how to replace a faulty USB cord.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$4.99
Locate the 5-pin connector on the mouse's motherboard.
Use the tweezers to carefully pull the 5-pin connector off. Do this by grasping the connector and wiggling it back and forth until it is off.
Once removed, place new 5-pin connector on in the same way.
2 autres ont terminé cette réparation.
