Aller au contenu principal
ThinkPad X1 Carbon Fan Replacement
Ce dont vous avez besoin
  1. ThinkPad X1 Carbon Fan Replacement, Loosen Cover Screws: étape 1, image 1 de 1
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Fan Replacement, Remove Cover: étape 2, image 1 de 1
    • Use a spudger to pop loose the cover and slide it off.
  3. ThinkPad X1 Carbon Fan Replacement, Disconnect Battery: étape 3, image 1 de 1
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove four screws holding battery in place and remove battery.
    • The 4 perimeter screws also hold the tow audio speakers in place. And there is a 5th screw dead center of the battery. The battery cable is not easy to remove, nor is it easy to re-connect.
  4. ThinkPad X1 Carbon Fan Replacement, Disconnect Fan Cable: étape 5, image 1 de 1
    • Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
    • These connectors are very delicate. Use care when removing cables.
  5. ThinkPad X1 Carbon Fan Replacement, Remove Fan: étape 6, image 1 de 1
    • Loosen screws and pull fan up and out of the case.
    • Be sure to apply heat sink paste when putting fan back on CPU
9 autres ont terminé cette réparation.
Mike
Membre depuis le 06/23/16
1 906 Réputation
5 tutoriels rédigés
Équipe
iReconstruction Membre de l'équipe iReconstruction
Business
1 membre
16 tutoriels rédigés
Un commentaire
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
marceec - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 28
30 derniers jours : 122
Total : 13,795
