Aller au contenu principal
ThinkPad Yoga 12 Battery Replacement
Ce dont vous avez besoin
  1. ThinkPad Yoga 12 Battery Replacement, Screws: étape 1, image 1 de 3 ThinkPad Yoga 12 Battery Replacement, Screws: étape 1, image 2 de 3 ThinkPad Yoga 12 Battery Replacement, Screws: étape 1, image 3 de 3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 Battery Replacement, Prying: étape 2, image 1 de 2 ThinkPad Yoga 12 Battery Replacement, Prying: étape 2, image 2 de 2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: étape 3, image 1 de 1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 Battery Replacement, Removing the screw: étape 4, image 1 de 2 ThinkPad Yoga 12 Battery Replacement, Removing the screw: étape 4, image 2 de 2
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
  5. ThinkPad Yoga 12 Battery Replacement, Lift: étape 5, image 1 de 2 ThinkPad Yoga 12 Battery Replacement, Lift: étape 5, image 2 de 2
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
  6. ThinkPad Yoga 12 Battery Replacement, Connecter: étape 6, image 1 de 3 ThinkPad Yoga 12 Battery Replacement, Connecter: étape 6, image 2 de 3 ThinkPad Yoga 12 Battery Replacement, Connecter: étape 6, image 3 de 3
    • Carefully pull the connector out from underneath the logic board to remove the battery.
9 autres ont terminé cette réparation.
[deleted]
Membre depuis le 03/18/18
1 324 Réputation
3 tutoriels rédigés
Un commentaire
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 27
Total : 6,522
