Introduction
This guide will show you how to disassemble the device in order to solve the problems with train movement and lights.
Ce dont vous avez besoin
The very top part is glued to the next one below. It has to be carefully cut of or using a very little saw to get it of the part below. Disconnect the connector for the lights and unscrew the four nuts.
11 autres ont terminé cette réparation.
39 commentaires
My Christmas train tree does not run nor is there music nor is there lights you put batteries in and nothing happens. I need help repairing it or someplace to send it to have it repaired the Hawthorne company no longer wants to take responsibility for and yet they continue to sell it
If nothing at all happens once you put batteries in then I assume that there is a broken connection from batteries to the PC board. The other possible cause is that the PC board itself is the problem. In any case you need to dismantle the tree according to the description because the electronic board is at the very bottom. If you can, check the voltage and the transistors on the PC board.
Hi,
Is there anyway to stop Santa from squeaking?
Thanks,
Noreen Snead
nmasnead@gmail.com
I am trying to put the Santa and reindeer on the top of the tree. Could anyone help me with this assemble?
