Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Thomas Ride On Train battery replacement
Ce dont vous avez besoin
    1. Thomas Ride On Train battery replacement, Open the seat: étape 1, image 1 de 1
      • Remove the seat by unscrewing the single screw located just by the backrest
      • Slide the seat backwards to unclip it
      • Unscrew the battery restraint
      Demander à FixBot
      Ajouter un commentaire
      • If you are replacing with an official replacement then it's a simple case of unclipping the old battery.
      • Alternative battery
      • If however you are swapping in an alternatively sourced battery you will need to cut off that clip.
      Demander à FixBot
      • The condition of the battery can most easily be told by charging it and seeing how much use you get out of it before it needs recharging again.
      • However if you have a multimeter then you can also look at the voltage of the battery.
      • Details of checking the battery
      Demander à FixBot
    2. Thomas Ride On Train battery replacement, Replacing the new battery: étape 4, image 1 de 1
      • If you are using a official replacement battery this again should be a simple case of clipping the new one in place.
      • Finish up by replacing the restraining clip making sure to avoid trapping any wires. Replace the seat up by sliding it firmly forwards then screwing down
      • Crimp or solder on suitable connectors for the new battery ensuring that the red and black wires are connected to the same connectors on the battery.
      • It is a good idea to ensure that the battery can disconnected for future diagnosis, external charging or replacement
      Demander à FixBot
2 autres ont terminé cette réparation.
6 commentaires de tutoriel
Hi,
I need a new battery 6v for Thomas ride on train.
Can you pls recommend a brand? Or can I use 12v instead ? Thanks
kowalska.sa - Réponse Partager
Can I use 2 6v battery's to make this train go faster??
Reggie - Réponse Partager
If you use a 12v or two 6v attached in series it could damage the sound board.
Two 6v in parallel would give you a longer run the between charges.
Andy from Workshopshed - Réponse Partager
The official battery is 6v 4Ah, check the dimensions against the battery compartment or old battery
http://www.hedstrom.co.uk/shop/spares/th...
When replacing battery on the train the negative wire came off a little silver rectangular piece hooked to it what is this part and do I need it or can I bypass it
Leonard Breyne - Réponse Partager
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 30
30 derniers jours : 101
Total : 16,506
