Aller au contenu principal
Three-way Switch Replacement
Ce dont vous avez besoin
  1. Three-way Switch Replacement, Three-way Switch: étape 1, image 1 de 2 Three-way Switch Replacement, Three-way Switch: étape 1, image 2 de 2
    • Locate and turn off the circuit breaker for your switch.
    • Try to turn the switch to ensure you turned the power off.
  2. Three-way Switch Replacement: étape 2, image 1 de 1
    • Use the screwdriver to remove the 15mm Flathead screws on the wall plate.
    • Remove the wall plate from the wall.
  3. Three-way Switch Replacement, Determine voltage absence: étape 3, image 1 de 2 Three-way Switch Replacement, Determine voltage absence: étape 3, image 2 de 2
    • While wearing insulated gloves, gently pull out the switch and use a Duspol or any other Voltmeter to test if there is voltage at the contacts.
    • You can also use a single pole phase tester, but that's not the proper way to do it.
    • Do not work on live circuits if you are not an experienced professional.
  4. Three-way Switch Replacement: étape 4, image 1 de 3 Three-way Switch Replacement: étape 4, image 2 de 3 Three-way Switch Replacement: étape 4, image 3 de 3
    • Label the black live or load wire which connects to the power or the device and usually on the down position of the switch.
    • Use the screwdriver to loosen the 5mm Phillips #1 screw so that you can remove the live or load wire from the switch.
  5. Three-way Switch Replacement: étape 5, image 1 de 2 Three-way Switch Replacement: étape 5, image 2 de 2
    • Label the two traveler wires where the up position is held by gold screws of the old switch.
  6. Three-way Switch Replacement: étape 6, image 1 de 3 Three-way Switch Replacement: étape 6, image 2 de 3 Three-way Switch Replacement: étape 6, image 3 de 3
    • Use the screwdriver to loosen the 5mm Phillips #1 screws so that you can remove these two traveler wires.
    • After the wires are removed, disconnect the old switch.
  7. Three-way Switch Replacement: étape 7, image 1 de 2 Three-way Switch Replacement: étape 7, image 2 de 2
    • You will find there are one or two wires left in the outlet box.
    • Ground wire is the bare copper wire.
    • The white one is the neutral wire that may be in another outlet box.
    • Please label the neutral wire and the ground wire.
  8. Three-way Switch Replacement: étape 8, image 1 de 3 Three-way Switch Replacement: étape 8, image 2 de 3 Three-way Switch Replacement: étape 8, image 3 de 3
    • Using your new switch, link two traveler wires to the positions with gold screws of the new switch and tighten the 5mm Phillips #1 screws.
    • Link the live or load wire to the position with a black screw and tighten the 5mm Phillips #1 screw.
    • Please ensure you link the wires to the correct places.
  9. Three-way Switch Replacement: étape 9, image 1 de 2 Three-way Switch Replacement: étape 9, image 2 de 2
    • If there is a green 5mm Phillips #1 screw on the new switch, please link the ground wire to and tighten it.
    • For the intelligent switch, there would be a green wire so that you can group the ground wire with the green wire and tighten them with a wire nut.
  10. Three-way Switch Replacement: étape 10, image 1 de 2 Three-way Switch Replacement: étape 10, image 2 de 2
    • There is an extra white wire on the intelligent switch.
    • Group the neutral wire with the white wire and use the wire nut to tighten them.
  11. Three-way Switch Replacement: étape 11, image 1 de 3 Three-way Switch Replacement: étape 11, image 2 de 3 Three-way Switch Replacement: étape 11, image 3 de 3
    • Turn the power on and check whether the new switch works.
    • Gently push the wires back into the outlet box.
    • You’ll also need to leave some space for the switch.
    • Secure the new switch with the 10mm Phillips #1 screws.
    • Finally, secure the wall plate.
2 autres ont terminé cette réparation.
Tao Zhuo
Membre depuis le 01/19/21
256 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G30, Melo-Thaiss Winter 2021 Membre de l'équipe York University, Team S1-G30, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G30
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 33
Total : 1,991
