Aller au contenu principal
Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement
Ce dont vous avez besoin
  1. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, J1 Screws on Throttle: étape 1, image 1 de 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: étape 2, image 1 de 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: étape 2, image 2 de 2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: étape 3, image 1 de 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: étape 3, image 2 de 2
    • Remove the two 7 mm J1 JIS head screws from the panel covering the buttons.
  4. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: étape 4, image 1 de 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: étape 4, image 2 de 2
    • Pull the panel that is covering the R2 button away from the throttle.
  5. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: étape 5, image 1 de 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: étape 5, image 2 de 2
    • Carefully push the R2 button from the outside of the panel.
    • Be cautious of the spring attached to the button as it can be easily lost.
  6. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: étape 6, image 1 de 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: étape 6, image 2 de 2
    • Remove the two 4 mm J1 JIS head screws from the panel covering the L2 button.
  7. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: étape 7, image 1 de 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: étape 7, image 2 de 2
    • Carefully push the L2 button from the outside of the panel.
2 autres ont terminé cette réparation.
Crystal Nguyen
Membre depuis le 09/11/17
621 Réputation
4 tutoriels rédigés
Équipe
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 membres
13 tutoriels rédigés
Un commentaire
Hello, m R2 button is broken. Do you know where i can print a new one ?
louis_tiquet - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 10
Total : 1,215
